New ac drive technology
Feb. 1, 2000
Using the speed of digital signal processors and advanced motor modeling, new technology will enable adjustable-speed drives to operate open loop and deliver equivalent performance to that produced by present units operating with closed-loop.
For many adjustable-speed applications, it is necessary to mount a tachometer, encoder, or resolver on the motor to produce a signal that is proportional to motor speed. Used as a speed feed back, this signal enables a drive to maintain the motor speed often within ± 0.01% of the commanded speed and to produce rated torque at or near zero speed.
For the last 8 years, engineers in Helsinki, Finland, have been working to change that. Although it sounds easy, it isn’t. The engineers well knew that an ac motor is relatively simple to build and maintain, but its mathematical model is highly complex with several differential equations. Never the less, their goal was to develop an ac drive technology that would:
• Eliminate the need for any speed feed-back device yet maintain speed within ± 0.5% or better.
• Offer unequaled open-loop response.
• Deliver rated torque at stall.
Provide smooth motor operation as it reverses through zero speed while delivering full torque.
• Reduce motor noise.
According to ABB’s Vice President, Standard Drives, Bob Eisenbrown, their engineers in Helsinki succeeded. While announcing this technological advancement, they emphasized that it took 100 man-years of research and three major advances — expanded motor modeling capabilities, advanced power unit control techniques, and the signal processing power to handle complex calculations. All are contained in the ABB drive technology — Direct Torque Control (DTC) — which can be operated as a speed or torque regulator. The basic algorithm of the speed controller is PID.
Here’s briefly how it works and what it will offer.
Start-up
After wiring is complete, and before the motor is connected to the load, the operator will enter the motor nameplate information into the drive memory. For some applications, this is sufficient. For others requiring higher performance, the drive can make an automatic identification run, which takes about 1-minute. During this, the drive runs the motor through a motion sequence to establish specific motor parameters, which are stored in a mathematical model of the motor. The motor parameters are stored in a flash memory so the information is retained even when power is removed from the controller.
Motor model
During operation, the model receives instantaneous motor current and dc bus voltage values plus the state of the power switches (conducting or not-conducting). The model then calculates the stator flux, torque, frequency, and speed for every control cycle. There is a cycle every 25 μsec (40,000 cycles per second). In addition, the model estimates the stator resistance. This value is based on the initial value obtained during the identification run and on subsequent motor duty.
Control circuits
In simplified terms, the control circuit, Figure 1, receives inputs for the commanded values for speed or torque and from the motor model. In a few microseconds, the circuit calculates the proper switch positions (on and off) for the six power switches. Unlike most ac drives that have specific modulation (also called chopping and switching) frequencies, the DTC technology determines the on state for each switch needed at that instant to produce the needed flux and its various components to develop the required torque. Generally, the on times produce a modulation frequency between 1.5 kHz and 3.5 kHz.
Granted, these frequencies are in the audible range, but the ABB engineers point out that there is no one prominent frequency as is often noticed in conventional drives. Instead, the DTC produces a white noise much like a fan or other “background” noise device.
DSPs and response
Digital signal processors (DSPs) combined with application specific integrated circuit (ASIC) technology make specific calculations rather than carry out instructions as do microprocessors. In fact, these relatively new technological advances are critical to making the new DTC drive technology a reality.
By using 40-MHz DSPs, the control circuit starts to react to a change in 25 msec. This gives a torque loop response of 300 msec to 5 msec, depending on the magnitude of the needed change. To put these values in perspective, Mr. Eisenbrown relates: “DTC’s response times (without an encoder or tachometer for feedback) of 300 msec to 5 msec compares to 20 msec for other high-performance vector drives fitted with encoders, and to the typical 150 msec for the newer sensorless flux-vector technology.”
Continue on page 2
In graphic form, Figure 2 shows how fast two drive types respond to an instantaneous 100% load change. The two types: a typical PWM (V/f) drive and a new drive incorporating DTC technology. The speed of the PWM drive drops over 60% while the DTC drive speed decreases about 12%.
Power circuit
The DTC power circuit Figure 3, closely resembles the circuit of a PWM drive. Both have a diode rectifier front end and six power control devices in the inverter section to change dc to controlled ac. Frequently termed switches, these devices are often insulated gate bipolar transistors (IGBTs).
DTC drives will use IGBTs in drives rated to about 400 hp, and gate-turn-off devices (GTOs) in larger ratings. For these larger units, the switching frequency will be in the 800-Hz range.
Costs
Operating open loop eliminates the need for a motor mounted tachometer, encoder, or resolver and the cost for running the leads back to the controller. In many installations these costs can account for 20 to 30% of the system installed cost.
Other benefits
DTC technology will also eliminate the need for additional parameter adjustments such as torque boost or starting mode selection such as “flying start.” This feature is needed when an inverter powers a fan or pump that may be rotating in the reverse direction when forward power is applied.
Applications
Drives with DTC are ideally suited for higher performance applications — many of which have traditionally been powered by dc drives — such as extrud- POWER TRANSMISSION DESIGN n FEBRUARY 1995 51 ers, large cranes and hoists, elevators, centrifuges, paper making machines, corrugators, printing presses, packaging machines, textile ranges, paper film and foil converting lines, and other applications with similar requirements.
Limitations
However, ABB points out that there will always be some special applications where more accuracy will be needed. For these, using an encoder with a DTC drive will increase the speed-control accuracy. Thus, open loop DTC will not be suggested for robots, machine tools, and machines handling fine fibers.
Product availability
Mr. Eisenbrown expects that drive controllers using the DTC technologies will be available later this year. The first units will be single-quadrant designs — motoring in one direction. Later in the year, four-quadrant units will be in production. These will offer motoring in both directions and the ability to regenerate power back to the ac power line.
To obtain more information on this new DTC technology from ABB Industrial Systems, New Berlin, Wis., please circle 421 on the readers service card. If this article is helpful, please circle 422 on the reader service card.
Related Articles
DSP to GO
March 13, 2024
March 13, 2024
March 13, 2024
March 13, 2024
