Machinedesign 2325 Shaft Lock1 0 0
Shaft locker
April 1, 2009
Now there is a way to lock components onto shafts and spindles where installation perpendicular to the shaft is not possible: Similar to threaded versions,
Now there is a way to lock components onto shafts and spindles where installation perpendicular to the shaft is not possible: Similar to threaded versions, the new Bearlok uses a set of evenly spaced socket-head capscrews to engage a high-strength tapered sliding collar, to evenly exert inward locking pressure to the shaft or spindle, while resisting the backwards creeping motion associated with other keyless locking devices.
This keyless shaft lock secures bearings, gears, pulleys, and other power transmission components to shafts and spindles while ensuring precise alignment, squareness, and axial location; it is engineered for applications where a balanced locking device is required for higher speed, and where greater holding strength must counteract shock and vibration. With more precise alignment and greater holding power than other locking collars, it is more suitable for an array of machinery and equipment.
VITAL STATS
On display: BLC, BL, and BLM (metric) Bearlok
Key features: Secures components to shafts when tangential access is not available; exhibits low shaft-to-face runout, for precise assembly
What it means to you: Better-aligned components with up to three times the holding power of conventional collars — without putting installation personnel through difficult mounting procedures
What else: Available for smooth-shaft diameters of 0.750 to 2.500 in., and for threaded shafts with ANSI/ASME threads 0.391-32 through 13.723-6 — Metric M10-0.75 through M200X3
Innovator: Whittet Higgins Co.
Central Falls, R.I.
(401) 728-0700
www.whittet-higgins.com
Precision Motion Control for Robotics Systems
April 8, 2024
Learn more about Precision Motion Control for your Robotic Systems through Harmonic Drive's latest Webinar!
April 3, 2024
Introducing the Mass Flow Rate Calculator
April 3, 2024
The KNF Mass Flow Rate Calculator makes it easy to convert volume flow rate to mass flow rate. Simply enter the volume flow and the gas or gas mixture.
April 3, 2024
