Servo couplings
March 1, 2009
Stainless steel bellows couplings Precision couplings Flex B and Flex K provide excellent kinematic properties with three types that offer different combinations
Precision couplings Flex B and Flex K provide excellent kinematic properties with three types that offer different combinations of stiffness, radial compensation, and axial motion for high-end servo drives.
Features & benefits
  • High torsional stiffness for drive systems requiring high torsional integrity
  • High positional accuracy, low risk of resonance
  • Three or nine convolutions, or two convolutions with cardan, for different shaft alignments
  • Flex M disc-type precision coupling available for high rotational speeds and motion integrity
Huco Dynatork
Altra Industrial Motion
(888) 999-9860
www.huco.com
Circle 151
CD couplings
A special coupling design features a CD disc that has high torsional stiffness, yet allows for misalignment in high-stress applications.
Features & benefits
  • Using finite element analysis, the CD disc can be easily modified along with changes in composite material
  • Custom disc designs (manufactured on laser cutting machines) can add to or lessen coupling flexibility or increase strength and stiffness
  • 40 standard CD coupling models and sizes to work from; custom couplings are configured much faster than couplings using all metal components requiring special dies and tooling
Zero-Max Inc.
(800) 533-1731
www.zero-max.com
Circle 152
Precision couplings
Servomax precision couplings are designed to handle 10,000,000 cycles at rated torque.
Features & benefits
  • Polyurethane insert damps vibration and absorbs slight shaft misalignment in lateral, axial, and angular directions while transmitting backlash-free torque
  • Where failure is a possibility and ease of maintenance critical, the EKH series allows easy installation and removal without disturbing motors and gearboxes; handles torque ranges from 15 to 19,000 in.-lb.
  • Three different insert hardness levels allow choice between torsion resistance and flexibility levels
R+W America
(630) 521-9911
www.rw-america.com
Circle 153
Flexible beam couplings
Zero-backlash beam couplings are machined from a single piece of aluminum and feature multiple spiral cuts to provide high torsional stiffness and torque capabilities.
Features & benefits
  • Multiple spiral cuts accommodate angular and parallel misalignment, as well as axial motion
  • One coupling series features two sets of three cuts, suitable for light-duty power transmission applications, such as coupling a servomotor to a leadscrew; the other series features two sets of two spiral cuts and is designed for precision applications
  • Aluminum or stainless steel; 20 body sizes available with ODs from 10 to 38 mm and bores from 2 to 19 mm
Ruland Manufacturing Co.
(508) 485-1000
www.ruland.com
Circle 154
