Machinedesign 1818 0710conveyor 0 0
Better by Design: Tip-top tap-ready conveyor
July 1, 2010
Conveyors are no strangers to dust: It's generated by rubbing corrugated boxes during packaging, the conveying of pet food or bakery confectionary, and
Conveyors are no strangers to dust: It's generated by rubbing corrugated boxes during packaging, the conveying of pet food or bakery confectionary, and in the processing of other granular products that go airborne and then settle. The trouble is that the very T-slots that simplify attachment of accessories to conveyors in these applications also collect and trap dust.
To address this issue, Dorner Mfg. Corp., Hartland, Wis., now offers DustPruf 2300 and 5300 Series conveyors that feature solid sides with indented guide grooves called SmartSlots — thin, continuous racing stripes that mark the sections of conveyor frame engineered to be thinnest and easily tapped — for the mounting of guides and automation accessories with self-tapping screws and a cordless drill, even on curved sections.
The new conveyors are suitable for dusty or dirty environments requiring occasional wipedown or spot cleaning, or in medical and pharmaceutical production, where dust is unacceptable. An FDA-approved, low-friction bedplate coating also reduces friction with the conveyor belt by 20% — so load capacity is increased that much for a given motor.
VITAL STATS
On display: Dorner DustPruf 2300 and 5300 Series conveyors
Key features: Streamlined design (with SmartSlots in the frame) eliminates points where particulates or debris can collect; recyclable aluminum frame
2300 Series: Widths range from 2 in. to 2 ft; lengths to 24 ft; motor at end or center of conveyor; same gearmotors, mounts, drive packages, and service parts as 2200 Series
5300 Series: Widths range from 8 in. to 3 ft (in 2-in. increments), lengths to 83 ft; end, nosebar, curve, and nosebar curve models; speeds to 260 ft/min., same gearmotors and mounts as 5200 QWIK conveyor
What it means to you: All the integration and add-on capabilities of a T-slot without the drawback of slots that collect debris
What else: Five-day delivery from time of order; comes with compatible stands with the same SmartSlot structure; reconfiguration is fast and convenient, and designers can easily convert 90° left-turning curves to right-turning curves; made in the USA
Innovator: Dorner Manufacturing Corp. (800) 397-8664 • www.dustprufconveyors.com
Precision Motion Control for Robotics Systems
April 8, 2024
Learn more about Precision Motion Control for your Robotic Systems through Harmonic Drive's latest Webinar!
April 3, 2024
Introducing the Mass Flow Rate Calculator
April 3, 2024
The KNF Mass Flow Rate Calculator makes it easy to convert volume flow rate to mass flow rate. Simply enter the volume flow and the gas or gas mixture.
April 3, 2024
