Basics of sliding metallic-bearing materials: Part 2
July 1, 2000
This is the second of a series on principles and characteristics of metallic plain bearing materials and how to optimize them in given uses. See June 1994 for Part 1.
We continue the discussion of bearing- material properties, covering some of the more important relationships among bearing-material properties and weardamage mechanisms.
Compatibility. This is an antiseizure and antiscore characteristic. It relates mostly to the ease with which the bearing material surface can adhere or weld to a steel or iron journal surface with pressure and heat and no lubricant or other interfering surface film. Potential for scoring and seizure exists in all boundary and thin-film lubrication conditions. There are only seven commercially significant elemental metals of good compatibility with ferrous journal surfaces: silver (Ag), cadmium (Cd), indium (In), tin (Sn), antimony (Sb), lead (Pb), and bismuth (Bi). Tin and lead show the most attractive combinations of cost, availability, and engineering properties. Both are used widely in bearing alloys because of their contributions to compatibility, either as the alloy base as in lead and tin babbitts, or as major alloy constituents as in leaded bronzes and aluminum-tin (Al- Sn) alloys.
Many nonmetals also show useful compatibility with steel. They include synthetic resins, carbon, cemented carbides, intermetallic compounds, and ceramics.
Conformability & embeddability vs. hardness & fatigue strength. Conformability and embeddability depend on yielding and plastic flow of the loaded bearing material. Therefore, soft, weak, low-modulus metals such as tin and lead have the best of these characteristics. However, harder, stronger, higher-modulus metals such as copper (Cu) and aluminum have high fatigue strength. You can get useful compromises among these sets of opposed properties by alloying to produce polyphase structures with intermediate properties. Also, you can get such compromises with layered constructions where at least one harder, stronger backing layer reinforces softer and weaker surface layers.
Bearing material microstructures. All commercially significant bearing metals except silver are polyphase alloys. Three basic microstructural types are:
• Type I — Soft Matrix with Discrete Hard Particles, Figures 2 and 3. Lead and tin babbitts are of this type. These alloys have lower compatibility, conformability, and embeddability than unalloyed lead or tin — hard intermetallic and metalloid particles are present, effectively increasing bulk-strength properties.
• Type II — Interlocked Soft and Hard Continuous Phases, Figures 2 and 3. Many copper-lead and leaded bronze alloys are of this type. Structures consist of continuous, mutually supporting copper and lead sponges. A large volume of lead helps compatibility. Conformability, embeddability, hardness, and strength are intermediate between those of lead and those of copper.
• Type III — Strong Matrix with Discrete Soft-Phase Pockets, Figures 2 and 3. Low-lead bronzes and some aluminumtin alloys are of this type. Structures consist of a continuous copper-base or aluminum- base metallic matrix that contains discrete pools or pockets of lead or tin. The strength of the matrix phase dictates conformability, embeddability, strength, and hardness. The soft metal phase exposed at the bearing surface enhances compatibility.
Alloys containing silicon (Si), such as aluminum-silicontin and aluminumsilicon- lead alloys are examples of mixed microstructures that combine Type I and Type III characteristics. Here, the aluminum matrix contains dispersed hard particles (silicon) and soft-phase (lead or tin) particles.
Bearing material design gained much with the recognition that effective load capacities and fatigue strengths of lead and tin alloys increase sharply when the alloys serve as thin layers intimately bonded to strong bearing backs of bronze or steel. Figure 4 shows the value of this principle in two-layer constructions like that of Figure 5 using a surface layer of lead or tin alloy, usually no more than 0.005 in. thick. Such a layer provides unimpaired compatibility, together with good conformability and embeddability. You can get other useful compromises between surface and bulk properties with an intermediate copper or aluminum alloy layer between the surface alloy layer and a steel back. In these three-layer constructions, surface layer thickness as low as 0.0005 in. offers even more favorable surface-and-bulk property compromises than you can get with two-layer construction.
Corrosion resistance. Bearing failure due to corrosion alone is rare. Corrosion usually interacts with mechanical and thermal factors to cause failure by fatigue or seizure in conditions the bearing could normally tolerate. You can avoid most bearing corrosion with oxidation inhibitors in commercial lubricating oils, and by periodic oil change. However, in some situations neither of these is dependable. There, use materials with inherently high corrosion resistance.
Continue on page 2
Commercially pure lead is susceptible to corrosion by fatty acids. Lead-base and copper-lead bearing alloys can corrode severely in acidic lubricating oils. Tin additions to lead above about 5% protect effectively against this kind of corrosion. Thus, tin is used extensively in lead-base bearing alloys. Acidic oils that contain sulfur attack copper and lead. This is of special concern with copper-lead and leaded bronze bearing alloys. A surface layer of a lead alloy containing tin, or a tin alloy, can provide effective protection. As long as the corrosion-resistant surface layer is intact, corrosion can’t damage the underlying copper-lead alloy.
Tin and aluminum bearing alloys are substantially impervious to corrosion by oil-oxidation products. They are used extensively where the potential for lubricating- oil corrosion is high. Although lubricating- oil oxidation and contamination are the most common causes of bearing corrosion, there are others. They include seawater, animal and vegetable oils, and corrosive gases. When you select and specify a bearing material for a given application, consider the anticipated service conditions and the corrosion potentials these conditions may involve.
Thermal effects. When selecting a bearing material, it is important to consider the reduced mechanical strength of bearing liner materials at high temperature. Fatigue strength, compressive yield strength, and hardness decrease significantly with increasing temperature. The softening curves in Figure 6 show lead and tin-base bearing alloys are most severely limited; copper alloys, least.
Load capacity. For a bearing material, load capacity is the maximum unit pressure at which the material can operate without excessive friction or wear damage. Capacity ratings published for designer guidance are usually upper limits, which may be safely used only with very good lubricant-film integrity, counterface finish, mechanical alignment, and temperature control.
In cyclic load service (such as in crankshaft bearings), fatigue strength is the primary limit to load capacity. For steady loads, capacity depends more on compressive yield strength, reflected in indentation hardness. In all situations, material strength at operating temperature governs. Thus, successful operation of sliding bearings depends on temperature and its control.
You may find load-capacity ratings useful as references, but you must recognize them as imprecise and somewhat judgmental approximations. They are not guaranteed or directly measurable.
*Material in this series is condensed from the chapter “Friction and Wear of Sliding Bearing Materials,” by George R. Kingsbury, ASM HANDBOOK, Friction, Lubrication and Wear Technology, ASM International, Materials Park, Ohio, 1992, pages 741-757. For ordering information about the entire book, contact ASM International, Materials Park, OH 44073-0002, ph. (216)-338-4634.
George R. Kingsbury, P.E., recently retired as Senior Engineer from Glacier Vandervell Inc., a major producer of metal plain bearings, is principal of his own metallurgical engineering consulting practice in Lyndhurst (Cleveland), Ohio. He is well known in the bearing materials field as an author, lecturer, inventor, and consultant.
Related Article
Basics of sliding metallic-bearing materials: Part 1
High-performance bearings boost professional cycling speeds
Bearing breakdown
March 13, 2024
March 13, 2024
March 13, 2024
March 13, 2024
