I/O modules
The G10 family of AS-Interface modules feature a revolutionary connect & done technology that eliminates mounting in many applications
The G10 family of AS-Interface modules feature a revolutionary connect & done technology that eliminates mounting in many applications.
The 40 × 27 × 22-mm module, with IP68/69K protection, fits into any cable duct and allows quick, convenient sensor connections using M12 pigtails.
The device’s single-piece housing uses a hinged cover design that simplifies connectivity, ensures reliable contact to the AS-Interface flat cable, and eliminates additional mounting requirements. For applications where mounting is required, two M4 screw holes are provided. The G10 has no gaskets, inserts, separate housing parts, or additional screws.
The yellow AS-Interface cable powers the sensors, and a continuous output current up to 1 A can be supplied from auxiliary power. All versions of the module come with bright diagnostic and status LEDs.
Pepperl+Fuchs
1600 Enterprise Pkwy.
Twinsburg, OH 44087
(330) 486-0001
www.pepperl-fuchs.us
© 2011 Penton Media, Inc.
