Magazine Issues
  • Jun. 13, 2013
    June 13, 2013
    ...More
  • May 23, 2013
    May 23, 2013
    Behind the corporate-strategy facade -- Hackers, start your motors, if you can -- Self-lubricating polymers bolster machine output -- New ways to damp vibration on linear axes -- Bearings designed to multitask --...More
  • May 9, 2013
    May 9, 2013
    Simulating your way to the victory circle Pumping new life into old machines Simple shaft supports eliminate realignment problems Additive manufacturing comes to metal foam When electric motors won't do...More
  • Apr. 11, 2013
    April 11, 2013 Machine Design
    Designing with Galfenol How gears improve motion designs Raising the bar on adhesive performance Redesigning with thermoplastic elastomers Motor makeover...More
  • Mar. 21, 2013
    March 21, 2013 Issue Machine Design
    Concept cars in Detroit How to Bond Steel to Aluminum Better Testing for EV Motors Cool Taillights: Thermal Management for Automotive LEDs...More
  • Mar. 7, 2013
    March 7, 2013 Machine Design
    What does the Future Hold? Carbon Fiber Comes to 3D Printing Drones That Can Move Mountains Electric Vehicles- The Real Action Is In Bikes Robots Go OPen Source...More
  • Feb. 13, 2013
    February 14, 2013 Machine Design
    Print Me! New developments in 3D printing How to deal with water hammer Nice threads: Basics of metal inserts Lubrication for life...More
  • Jan. 17, 2013
    January 17, 2013 Machine Design
    Basic Nonlinear FEA Here Coms Reusuable Space Planes New Medical-Device Standards Getting Up to Speed on Valve Technology High-Tech Materials From the Space Program...More
  • Dec. 22, 2012
    December 22, 2012 Machine Design
    Best 3D printing Web sites Best Engineering blogs Best Engineering Forums...More
  • Dec. 6, 2012
    December 6, 2012 Machine Design
    Technology: The backbone of business Best LinkedIn engineering groups...More
  • Nov. 22, 2012
    November 22, 2012 Machine Design
    Rethinking the Snowmobile Multiphysics Software builds a better heat sink Better economics for industrial fiber optics Casting with Quartz...More
  • Nov. 8, 2012
    November 8, 2012 Machine Design
    How Hot Rodders Soup up Electric Motors How to Make CAM Followers in Plastic How to Make Plastic Out of Plants How to Dodge Danger With Air Logic...More
  • Oct. 18, 2012
    October 18, 2012 Machine Design
    Off Tilt: Where Industrial Gyroscopes Excel Simulation Helps Calculate Trajectories Prototyping With Springs Cloud-Based Help For Motion System Designers...More
  • Oct. 4, 2012
    October 4, 2012 Machine Design
    Getting Motion Systems Up and Running Fast Meshing For CFD Better Die Casting, Tighter Tolerances Adhesives That Cure With Visible Light...More
  • Sep. 20, 2012
    September 20, 2012 Machine Design
    Hydraulic Fans Keep Equipment Cool Closing The Loop With Stepper Motors How LEDs Degrade In Optocouplers A Hot Time With Etched-Foil Heaters...More
  • Sep. 6, 2012
    September 6, 2012 Machine Design
    Space truckin' with SpaceX Safety shock: Sensing ground faults in industrial applications Manufacturing for the masses Industry could take a shine to copper-rotor motors...More
  • Aug. 23, 2012
    August 23, 2012 Machine Design
    Small copper tubes make a big impact on airconditioner efficiency Plastics lose weight with glass bubbles Going places with long-travel piezomotors Protecting fluid circuits with edge-welded bellows Made in the U. S. A....More
  • Aug. 9, 2012
    August 9, 2012 Machine Design
    Two sides of a green-energy failure  Rotary actuator increases speed, rotation, and response while cutting costs  Electric motorcycle tops 200 mph  Should the U.S. switch to natural gas for transportation Getting energy savings from pneumatic systems...More
  • Jul. 19, 2012
    July 19, 2012 Machine Design
    Tips & Traps in GD&T Basics of Ball Splines Resolution and Accuracy in 3D Printing Faster Molding With High-Flow Polycarbonates Better Ways to Assemble Peek Parts...More
  • Jun. 14, 2012
    June 14, 2012 Machine Design
    “Looks good!” Amateurs chase rocket prize The Changing Dynamics of LED Fabrication U.S. Manufacturing Strengths Variable-Speed Pumps Make Hydraulics Energy Efficient Precision Parts With Hydroforming...More
  • May 24, 2012
    May 24, 2012 Machine Design
    Indy: New engine Indy and chassis take to the track Smooth, Tough Coatings with Diamond-like Carbon The Physics Behind Keystrokes Embedded Electronics Go On a Power Diet...More
  • May 10, 2012
    May 10, 2012 Machine Design
    Better Ways to Catch the Wind A Magnetic Brake Without Cogging or Nonlinearities Ultraprecise Machining Holds Submicron Tolerances Software Analyzes Bearing Performance Dimensional Tolerances Simplify Engineering Tasks...More
  • Apr. 19, 2012
    April 19, 2012 Machine Design
    Sealed Bearings Go Green Predictive Modeling for Better Manufacturability When Precision Bellows Outperform Coil Springs Engineering Salary Survey: Where do you fit in?...More
  • Apr. 5, 2012
    April 5, 2012 Machine Design
    Lightening the Load With Modern Steels Newest Sailor: A Firefighting Robot High Pressue Challenge Pump-Seal Designs Internal Permanent Magnets Give Motor Design a New Look...More
  • Mar. 22, 2012
    March 22, 2012 Machine Design
    Future Technology Radios in Space: SDRs fpr the Space Station Will Aluminum-Ion Batteries Make Lithium-Ion Obsolete? A Glimpse of the Futre Through Concept Cars Engineering For the Other 90%...More
  • Mar. 8, 2012
    March 8, 2012 Machine Design
    Popping the Cork on 3D CAD Training Recycling Thermo Formed Packages Looking Good With Structural Thermosets Setting Standard For Being Green More For Less With Oscilloscopes...More
  • Feb. 9, 2012
    February 9, 2012 Machine Design
    Designing gearboxes for efficiency Analyzing Trade-Offs Between Servos and Stepper Motors Taming Electrical Noise in Motion Systems More Manufacturers Want to "Make It In America" How to Use Thin-Walled Bushins the Right Way...More
Connect With Us
