Whether for packaging, life sciences, office equipment or factory automation, smooth motion, fast accelerations and a high degree of accuracy are hallmark requirements for linear movement actuators. Increasingly, miniaturization has added the additional requirement of compactness.
One system that can meet all of the above requirements in its conversion of motor torque to linear thrust is the single axis ball screw actuator. Ball screws convert rotary motion to linear motion, or torque to thrust, and vice versa. The ball screw actuator is a combination of a ball screw on which, to eliminate backlash, a slide block or nut’s movement is guided by recirculating steel balls that roll between the block and raceways of guide rails.
