In LEDs heat and high currents hasten the dimming process which can lead to unreliable operation in LED-powered optocouplers. Some simple and straight-forward analysis will keep their light shining bright....More
To make a 10-µm thick flexible battery, researchers deposit battery materials onto a brittle mica substrate and then use sticky tape to peel the mica substrate away layer by layer....More
The surest way to make lightemitting diodes that are efficient and bright is to fabricate them on a substrate made of the same material as the LED itself...More
Combine blue, red, green, and yellow laser light and you will get white light, but perhaps a white light you wouldn’t want illuminating your living room...More
