A new line of high-durability cables helps prevent downtime and replacement for washdown, temperature, and weld-slag situations.
Silicone, silicone-tubed, and PTFE cables resist burns from hot weld sparks and prevent buildup over time that causes shorts and failures.
Stainless-steel braid and flexible conduit cable versions resist abrasion and crush to prevent cable abuse.
ECOLAB and IP69K-rated cable versions, with stainless hex nuts, resist caustic washdowns and chemicals that eat through cable jackets.
 Fiberglass jacket and thermoplastic cable versions prevent high-temperature melting and premature aging of cables.
Balluff Inc., 8125 Holton Dr., Florence, KY 41042, (800) 543-8390, www.balluff.us
