Internal Combustion Engines
Nov. 15, 2002
The most transportable and rugged sources of power are IC engines.
Most industrial internal combustion (IC) engines in the low-power range, about 30 hp or less, are gasoline powered because diesel engines are too heavy and costly. For example, in a small engine-powered water pump, a gasoline engine would account for perhaps 60% of the cost of the total package. With diesel power, the cost would be closer to 90%.
Thus, in the low-power range, the choice of engine centers largely on such factors as a choice between four and two-cycle operation and between cast-iron or aluminum construction.
The four-cycle engine is generally the preferred gasoline power plant. It has a reputation for long, trouble-free operation, idles smoothly and operates well at low speeds, does not require lubricant in the fuel, and generally does not have an exhaust with visible smoke.
Small engines are normally air cooled for simplicity and weight savings. However, water cools larger, stationary engines most efficiently.
Up to about 40 hp, four-cycle engines usually have simple L-head valve arrangements, which are less costly than an overhead cam. The overhead-cam arrangement provides more power and fuel economy and is generally found in larger engines.
Small engines use the same simple breathing mechanism and carburetor found on automotive engines. More complicated fuel injection and supercharging is reserved for larger, more expensive engines and for diesels.
Above 10 hp, four-cycle engines are normally made of cast iron. With smaller engines, the buyer has a choice between cast iron and die-cast aluminum. The aluminum engine is less costly if manufactured in large quantities.
Iron is said to wear better, but proponents of the aluminum engine say it lasts equally long if properly maintained. Iron has a greater tolerance to dirt, while dirt ingestion is quite harmful to an aluminum engine.
Automotive, marine, and aircraft engines are considerably more sophisticated than small industrial engines, and aluminum is used successfully in large engines in these applications.
A two-cycle engine puts out considerably more power than a four-cycle engine of the same size. The advantage of the two-cycle in power-to-weight ratio runs from 50% to as high as 300% or more. For example, a 40-hp four-cycle engine might weigh 250 lb, while a two-cycle engine of the same power weighs only 65 lb. One 2-cycle engine develops 80 hp from only 440-cc displacement.
Because of this high-power-to-weight ratio, the two-cycle engine is generally preferred for sport vehicles or where the engine must be lifted, held, or carried by hand. Power saws and most outboard marine engines are two cycle, as are most snowmobiles.
New developments in this area have automakers rethinking previous two-cycle engine concepts. One research firm found that by finely atomizing the fuel, combustion is more complete, exhaust is clean enough to dispense with the catalytic converter, and idle is more carefully controlled.
In other applications, the two-cycle engine has an unfavorable reputation for rough idle, poor operation at low speeds, temperamental behavior, and rapid fouling. Because they tend to operate best at high speed, they may have short service lives. Also, lubricant must be added to the fuel.
To their advantage, first cost is roughly 70% that of an equivalent four-cycle engine made in the same production volume. Two-cycle engines are usually made of aluminum as a weight-saving measure.
Diesels generally become competitive with gasoline engines above 30 hp, and they tend to be a more logical alternative as power demand increases. They are normally chosen because of their operating economy and greater durability. In general, a diesel costs about 2 1/2 times as much as a gasoline engine, but on the average a diesel lasts about 2 1/2 times longer. Besides being more costly than gasoline engines, diesels also tend to produce more noise and vibration. Diesels also run over a narrow rpm range and generally require considerable shifting when used in vehicles without torque converters. They require fuel injection, which contributes to their higher cost.
Diesels have acquired their reputation for being rugged heavy engines primarily because they are built to withstand the high firing forces and high cylinder pressures that are a consequence of the high compression needed to produce spontaneous ignition.
Sometimes the choice of an engine is based on other than economic reasons. The trend toward fuel standardization, for example, often dictates the use of small diesels at installations already using large diesels. The trend toward large diesel-powered farm tractors, for example, encourages the use of smaller diesel farm engines so only one type of fuel is stored.
Diesel fuel is less volatile than gasoline and, therefore, safer to handle. And diesel fuel is subject to less pilferage than gasoline, a factor causing many building contractors to consider diesel power for small engines. Many companies have standardized on diesel power for all engines; most engines used on oil-drilling rigs are diesel.
Geographic locale can also influence choice of diesel versus gasoline. European countries, for example, are heavily inclined toward diesel power even for engines well under 30 hp.
As with gasoline engines, there is a choice between two and four-cycle diesels. However, diesels have been perfected and refined to the point where there is little outward functional differences between two and four-cycle operation in terms of power, economy, or durability.
Two-cycle diesel operation requires a mechanical blower to force-feed air so the engine is aspirated sufficiently. This is in addition to turbochargers (exhaust driven) often used on both four and two-cycle diesels.
The Wankel engine in terms of functional characteristics -- including weight, power output, efficiency, and speed -- resembles a two-cycle gasoline engine. In short, the Wankel tends to save a bit more weight and space compared to a conventional four-cycle engine. This saving ranges from a trivial amount in small engines, up to a significant amount when compared with a large automotive V8. Here, the Wankel weighs about half as much and has about one-third the size of a four-cycle piston engine.
Over the long term, a few researchers expect the Wankel, with its four-cycle operating principle, may prove to be superior to the two cycle. Originally, the Wankel was plagued by poor combustion-chamber sealing and high fuel consumption. But ongoing development has lead to significant improvements in sealing and reduced fuel consumption.
The Wankel has gained acceptance in some quarters of the automotive market, but currently it is not a contender for industrial applications. However, some large industrial rotary engines have been designed specifically for packaged applications that include compressor, generator, and pump drives. Basically, these rotary engines are high-power low-speed units.
The gas turbine is exceedingly well suited to applications where considerable power output is required at constant speed. For example, one of their most important industrial uses is in driving huge electric generators to augment steam generation under peak demand at power companies. However, gas-turbine engines are expensive both to purchase and operate. Electric power generated at the utility-company level by a gas turbine costs from three to four times as much as that produced from a steam turbine.
The cost of a gas turbine is in the range of $15 to $35 per hp, whereas piston engines normally cost in the range of $1 to $10 per hp. The high cost of the turbine stems from the need for expensive materials to withstand the high temperatures generated.
Turbines have poor fuel economy under light load, and they take considerable time to gain speed under acceleration. Thus, they tend to make poor automotive engines. They are better suited to heavy trucks and buses and to high-power stationary applications where they run at a generally uniform high speed. Despite its drawbacks, a 1,500-hp turbine engine drives the Army's M1 battle tank. The engine can propel the 40-ton machine at speeds exceeding 40 mph. Nevertheless, this application is out of the ordinary.
External combustion Stirling engines are not industrially significant at this time because they have faced stiff competition from well-established internal-combustion engines. Moreover, Stirling engines tend to be complex, cumbersome, and expensive to manufacture.
Still, there is interest in the design in automotive circles because of inherent high efficiency and low exhaust emissions. The U.S. government, for example, has sponsored a program with the goal of making the Stirling a fuel-efficient, economical alternative to the IC engine in automotive applications. The first commercial applications, however, for the Stirling engine are in a portable electric generator set for recreational and government-operated vehicles.
