ZQ Compact Vacuum Generator Modules
May 19, 2005
ZQ Compact Vacuum Generator & Control Modules are just 10-mm wide, and come with a built-in vacuum venturi, 30-mm suction filter with replaceable element, solenoid valves, and a digital vacuum switch.
ZQ Compact Vacuum Generator & Control Modules are just 10-mm wide, and come with a built-in vacuum venturi, 30-mm suction filter with replaceable element, solenoid valves, and a digital vacuum switch. ZQ manifolds also come standard with One-Touch tube fittings for simple connection to an air supply and pilot exhaust.
The ZQ Series modules are one-third smaller than the company's ZX Series vacuum modules but perform the same. The venturi generates up to 25-in. Hg and suction flow rates to 0.7 cfm. ZQ modules each weigh 4 oz, and up to eight modules can be hooked to a common manifold.
SMC Corp. of America
14191 Myford Rd.
Tustin, CA 92780
(714) 669-0941
smcusa.com
March 13, 2024
March 13, 2024
March 13, 2024
March 13, 2024
