Wire duct for control-cabinet wiring - Phoenix Contact
Nov. 13, 2009
Clipline wire duct keeps cabinet wiring neat and secure. Fingers on the ducts have two score lines for easy removal.
Clipline wire duct keeps cabinet wiring neat and secure. Fingers on the ducts have two score lines for easy removal. The flexible fingers will not snap when the wire is run through them. The wire duct’s notched score line eliminates the need for notching pliers to break off the fingers. However, breaking the wall will require the use of a cutter.
The cover’s contour lets it snap on easily and fit securely. The wire duct ranges in size from 25 to 120 mm.
Phoenix Contact, 586 Fulling Mill Rd., Middletown, PA 17057, (800) 888-7388, www.phoenixcontact.com/wireduct
