Ultraslim Direct-Drive Linear Actuator
May 10, 2007
The STA11 direct-drive linear actuator comes with a 14-to-232-mm stroke length at a peak force of 92 N and peak velocity of 4.7 m/sec.
The 28-mm mounting center makes a 10-actuator assembly less than 12-in. wide. The built-in solid-state position sensor provides ±12-µm repeatability and a 1-Vpp sin/cos output, eliminating the traditional external encoder and simplifying installation. The thrust-rod diameter is 11 mm while the forcer measures 61 × 26 mm and is rated for 75-V operation. The STA11 is also food safe and meets IP67 wash-down specifications. The unit has the same form factor as regular pneumatic and electric actuators and conforms to international mechanical standards.
Copley Controls Corp.,
20 Dan Rd., Canton, MA 02021,
(781) 828-8090,
copleycontrols.com
RS Expert Advice Podcast, Episode 17: Energy Storage Systems
In this episode of the RS Expert Advice Podcast, Joel Boone and Olivia Koicuba of Phoenix Contact introduce energy storage systems, applications, and components, including various...
