Ultralow Temperature Grease
Nov. 3, 2005
Molykote 33 extreme-low-temperature bearing grease withstands temperatures ranging from –100 to 400°F (–3 to 204°C).
Molykote 33 extreme-low-temperature bearing grease withstands temperatures ranging from 100 to 400°F (3 to 204°C). It lubricates plastic gears, bearings, and cams, as well as metal and rubber parts that must operate despite low temperatures, severe weathering, and oxidation. It can also lubricate photographic, optical, and surveying equipment components as well as oscillographs, lowtorque instruments, and starter clutch drives. The grease is available in light and medium consistencies (NLGI #1 and #2).
Dow Corning Corp., Box 994, Midland, MI 48686 (989) 496-7881 www.molykote.com
