Tapered Caps And Plugs
July 22, 1989
Tapered Caps and Plugs from Caplugs Div.
Tapered Caps and Plugs from Caplugs Div., Protective Closures Co., Buffalo, are recommended for MIL Std., and SAE-type fittings, threaded external and internal N.P.T. fittings, and nonthreaded standard weight pipe. Made from pliable polyethylene, they fit snugly and are removable. The caplugs also come in green Flextemp, a flexible thermoplastic rubber for extreme temperatures ranging from –90 to 300?F. Also available in lowdensity polyethylene yellow, the WW Series has a wide, thick flange which is accepted by the aircraft industry. Shallow tube plugs, grease caps, lift-tab plugs, center-pull tapered plugs, recyclable paper caplugs, and silicone rubber closures are also available.
