Swivel-lifting eye bolts - J.W. Winco Inc.
The Series GN 581 swivel-lifting eye bolts come in metric sizes.
Aug. 12, 2010
The Series GN 581 swivel-lifting eye bolts come in metric sizes. The bolt’s ring is forged and annealed steel with a special bright pink powder-coated finish that changes color to indicate exposure to high temperatures. The threaded socket-head bolt is made from European standard 10.9 grade steel, and the hex-key cover plate is zinc-plated steel.
These eye bolts are mounted in a bearing and can be rotated. The ring can be positioned in the direction of the load for optimum strength. A special cap screw cannot be removed from the ring.
J.W. Winco Inc., 2815 S. Calhoun Rd., New Berlin, WI 53151, (800) 877-8351, www.jwwinco.com
© 2010 Penton Media, Inc.
