Stiction-Free Air Cylinders
A line of air cylinders nearly eliminates what is known as stiction; a common problem that causes pistons inside of air cylinders to stick at the beginning of a stroke.
March 22, 2007
The cylinders feature self-aligning graphite pistons fitted to Pyrex-lined stainless steel cylinders. They serve in –85 to 302°F applications that call for a smooth range of motion at pneumatic pressures down to 0.2 psi. The cylinders need no oil or seals, and all exposed surfaces are stainless steel or nickel.
Isotech Inc.,
777 Schwab Rd., Suite T, Hatfield, PA 19440,
(800) 314-3332,
isotechinc.com
