Stainless Valve/Actuators
Oct. 26, 2006
Stainless valve/actuator packages are designed to be economical in chemical, corrosive, and caustic environments.
Available for next-day delivery, the allstainless packages combine 316 SS ball valves with 316 SS rack-andpinion actuators. Shipped preassembled, the packages are available with Triac Series 2 and 3 full-port stainless valves with investment cast bodies, blowout proof stems, and threaded, sanitary or flanged ends. Triac stainless-steel rackand-pinion actuators feature 316 SS body, pinion, and pistons for easy service in problem environments. Actuators are available in double-acting and springreturn versions. The actuators offer Namur accessory mounting and ISO5211 mounting dimensions. The actuators come with electropolish finish and permanent lubrication.
A-T Controls, 11363 Deerfield Rd., Cincinnati, OH 45242, (513) 530-5175, a-tcontrols.com
