Linear actuators
Cala 36 linear actuators are engineered with motor and drive spindle connected in-line through a planetary gear assembly, achieving a compact design for limited space.
FEATURES & BENEFITS
  • 12 or 24 Vdc
  • Loads to 600 N, speeds of 31 to 17 mm/sec, stroke lengths of 50 to 200 mm
  • Options include front attachments for easy, secure installation; limit switches; cable; control systems; and hand switches
SKF ACTUATION SYSTEMS
Bethlehem, Pa.
(610) 861-4834
www.linearmotion.skf.com
Circle 121
Linear motors
Linear motor family P01-48×240 features standard and fast winding options, for maximal force and high payloads, and minimal position times in long-stroke applications.
FEATURES & BENEFITS
  • 580 N peak force
  • IP 67 motor connector rating
  • Maximum stroke lengths of 180 to 1,440 mm
LINMOT INC.
Delavan, Wis.
(877) 546-3270
www.linmot.com
Circle 122
Optical linear scale
Absolute sealed LC 182 optical linear scale covers measuring lengths to 4,240 mm.
FEATURES & BENEFITS
  • Constant signal quality over entire length
  • Resolution down to 0.02 µm, maximum traversing speed to 120 m/min
  • Single-field scanning, with large scanning window reduces contamination effects
  • High traversing speeds, increased natural frequency
HEIDENHAIN CORP.Schaumburg, Ill.
(847) 490-1191
www.heidenhain.com
Circle 123
Linear-type stepper motor
LinearStep offers linear motion in a rotary size package without the associated costs of rotary stepper motors.
FEATURES & BENEFITS
  • 25 to 35 mm outside dimensions
  • Ball bearing support and durable motor case promote long life
  • Thread spec and Neodymium magnet rotor for high thread efficiency and large driving force
NIPPON PULSE AMERICA INC.
Radford, Va.
(540) 633-1677
www.nipponpulse.com
Circle 124
Miniature linear guide/slide
Mini-Rail LS/MS self-lubricating, screw-driven linear guides/slides provide a compact, robust, light-weight, low-cost, smooth, and quiet motion control solution.
FEATURES & BENEFITS
  • Precision ball bearings support lead screw and pre-loaded drive nut for precision control and accuracy
  • No sealing, no particulate emission, corrosion-resistant, and tolerant of high temperatures
  • 6 different lead screws and standard motor mounts
PACIFIC BEARING CO.
Rockford, Ill.
(800) 729-9085
www.pacific-bearing.com
Circle 125
