Spotlight: Cable and cable carriers
Jan. 1, 2007
VFD cable Shielded Olflex VFD Slim cable is a thinner RoHS-compliant motor supply cable. Features & benefits Surge Guard protection resists non-linear
VFD cable
Features & benefits
  • Surge Guard protection resists non-linear power distortions of VFD drives
  • PVC jacket is TC approved for UL and CSA standards for 600 V
  • Smooths out stranded copper
  • Disperses increases in voltage caused by wave reflections, harmonics, and spikes
  • Prevents conductor and cable failure
  • MSHA-approved; tested to ICEA-T-24-380 corona test
Lapp USA
Florham Park, N.J.
(888) 456-3539
www.lappusa.com
Circle 151
Continuous-flex cables
Chainflex continuous-flex cables eliminate corkscrewing, loss of continuity, and insulation damage.
Features & benefits
  • Conductors are bundled (not layered) for uniform radius
  • More than 800 sizes and styles of power and control cables, air hoses, data, servo, and fiber optic cables
  • Twisted wires have special pitch length
  • Pulling and compressing forces balance one another around high-tensile center cord for inner stability under bending stress
Igus Inc.
East Providence, R.I.
(800) 521-2747
www.igus.com
Circle 152
Round, flat cable assemblies
FireWire high-flex round and flat cable assemblies prevent lost data or data integrity issues by maintaining stable attenuation over flex life.
Features & benefits
  • 2, 3, 4.5, and 7.7 m lengths; custom lengths available
  • Flex with no bit errors or loss of data
  • Round assemblies tested to 5 million cycles in rolling flex motions on bend radius of 50 mm
  • Flat assemblies tested to 20 million cycles in rolling flex motions on bend radius of 20 mm
W.L. Gore & Associates Inc.
Elkton, Md.
(800) 445-4673
www.gore.com
Circle 153
Shielded VFD cables
VFD lean TR flexible motor supply cables reduce problems related to voltage spikes, harmonics, and power distortions.
Features & benefits
  • Rated for 600-V tray cable as well as UL/CSA/VDE and CE approved for 1,000 V
  • Installs in wet, dry, indoor, and outdoor locations; is UV-resistant
  • Rated for direct burial
  • Braid and foil shield protects against excessive interference
SAB North America
Fairfield, N.J.
(866) 722-2974
www.sabcable.com
Circle 154
Custom cable carriers
Cable carriers use standard components customized to required specifications and come in fiber-glass filled Nylon, zinc-plated steel, and 304 and 316 stainless steel.
Features & benefits
  • For hose cable loads to 40 ft unsupported
  • Standard sizes from 0.4 to 4.75 in. × 0.59 in. to any width
  • Modular sizes from 0.75 in. high for any width
  • Temperatures from -40° to 250° F
Gortrac, Div. of A&A Mfg. Co. Inc.
New Berlin, Wis.
(262) 786-1500
www.gortrac.com
Circle 155
Industrial Ethernet cables
Line of DataTuff industrial Ethernet cables includes enhanced four-pair, category 5e twisted pair cables with bonded-pair technology for high electrical performance.
Features & benefits
  • Low smoke, zero-halogen, unshielded version features 24 AWG solid bare copper conductors with rip cord, polyolefin insulation, and 0.30-in. sunlight-resistant jacket
  • Shielded version also includes Beldfoil shield
  • Waterblocked/burial shielded cable includes above features and sunlight and oil-resistant PE jacket
Belden
Richmond, Ind.
(800) 235-3361
www.belden.com
Circle 156
March 13, 2024
March 13, 2024
March 13, 2024
March 13, 2024
