Spindle-Lift Tables
Sept. 16, 2004
DryLin SLW is a compact, flat linear table with a spindle drive. It delivers high torsional strength with a height of about 11/8 in.
It uses DryLin W linear guides. Another Model in the line is the DryLin HTSP, which is equipped with plastic crossbars and slides. Its weight can be reduced by combining the table with a carbon shaft and aluminum spindle. The stroke is always adjustable, either manually or by a servomotor. The bearings and guide systems have a low coefficient of friction and are corrosion and wear-resistant.
igus inc., Box 14349, East Providence, RI 02914,
(401) 438-2200, www.igus.com
