Speed regulator- Deschner Corp.
The Super-K Model Kinechek speed reducer handle loads up to 1,200 lb.
March 8, 2010
The Super-K Model Kinechek speed reducer handle loads up to 1,200 lb. The regulator’s mirror-finished, hardened tool-steel, high-pressure cylinder has an adjustable flow-control passage. The cylinder is mated to an all-metal piston with no sliding seals, which lets the plunger rod move smoothly at a constant rate throughout the entire stroke. Super-K’s are used extensively in robotics, food-processing equipment. and packaging machines.Deschner Corp., 3211 West Harvard St., Santa Ana, CA 92704, (714) 557-1261, www.deschner.com
