Shake, Rattle, And Off!
June 16, 2005
Vibration monitors detect both under and overvibration conditions that signal impending failure, minimizing risk of catastrophic equipment damage and expensive shutdowns.
The VS-XP Series targets numerous devices including fans, turbines, large motors, gearboxes, and vibratory conveyors.
The adjustable alarm trip is programmed to accept a range of vibration velocities. Sensing overvibration prevents catastrophic failure of equipment from imbalance conditions. Less obvious benefits involve sensor alerts on lower-thannormal vibrations where correct vibrations are required for proper operation such as vibratory conveyors.
Sensor range settings include vibration velocities from 0.1 to 26 ips rms. An adjustable setpoint delay prevents false trips of the selectable over or undervibration alarm. The VS-XP provides either an npn or SPDT relay output. The sensor uses 24 Vdc at 30 mA.
Electro-Sensors Inc.,
6111 Blue Circle Dr., Minnetonka, MN 55343,
(800) 328-6170,
electro-sensors.com
Strategizing for sustainable success in material handling and packaging
Download our visual factory brochure to explore how, together, we can fully optimize your industrial operations for ongoing success in material handling and packaging. As your...
Fueling the Future of Commercial EV Charging Infrastructure
Miguel Gudino, an Associate Application Engineer at RS, addresses various EV charging challenges and opportunities, ranging from charging station design strategies to the advanced...
