This ensures components are properly positioned and not tilted on the shaft and there is even pressure on interfaced components. A circular groove on the collar indicates the precision face. The collars come in aluminum, black-oxide carbon steel, stainless steel, and engineered plastic. One and two-piece clamp-style designs with bore sizes from 3 to 80 mm are available. Clamp-style collars have higher holding power because they wrap around the shaft when tightened, and the two-piece style can be installed without removing other components.
Ruland Mfg. Co. Inc., 6 Hayes Memorial Dr., Marlborough, MA 01752, (508) 485-1000, ruland.com
Sept. 16, 2025
Sept. 16, 2025
Aug. 22, 2025
