The Model HP servomotor adapter is designed to simplify servomotor mounting. The adapter features true double-enveloping worm-gear technology. Specifications include 3, 3.5, and 4-in. center distances; up to a 260-mm sq motor frame; 19,160 lb-in. (single-reduction) output torque; 5:1 to 60:1 single-reduction gear ratio and up to 3,600:1 in double reduction; backlash levels from zero to 15 arc-min; and solid, hollow, and shrink-disc output options.
Cone Drive, A Textron Co., 240 E. 12th St., Traverse City, MI 49684, (888) 994-2663, conedrive.com
