Serial Communication Card Uses RJ-45
Jan. 12, 2006
Designed for applications that require many serial communication connections using RJ-45 connectors like those in ATM machines, the PCI-1610AJU has four RJ-45 serialcommunication connections on a PCI-compatible interface card.
The card works with both the older 3.3 V as well as the new 5-V PCI bus. The 123-mm card also provides support for Microsoft XP Embedded with drivers on solid-state disk for improved reliability, vibration resistance, and compact installation. Up to four 1610AJU cards can be used simultaneously. The card comes bundled with Icom Tools software and four RJ-45-to-DB9 adapter cables.
Advantech Corp., 1320 Kemper Meadow Dr., Suite 500, Cincinnati, OH 45240, (877) 294-8989, eautomationpro.com
March 13, 2024
March 13, 2024
March 13, 2024
March 13, 2024
