Seals for Exhaust Valves
Jan. 25, 2007
Exhaust gases can form a sticky gum or hard deposits that often cause premature seal or bearing failure.
One solution are double-delta seals that use of PTFE components riding energized by an O-ring. The O-ring creates a balance between the desired leakage, friction, and response time. Glyd Ring II seals reduce tolerance stack-up and its elastomer is bonded to the PTFE. In the final seal, the Variseal, the elastomer is replaced with a slant coil spring that energizes the seal, thus making sealing friction more consistent.
Trelleborg Sealing Solutions, 510 Burbank, Broomfield, CO 80020, (303) 465-1727, trelleborg.com
March 13, 2024
March 13, 2024
March 13, 2024
March 13, 2024
