Screen fittings
Dec. 8, 2005
Screen fittings are designed for in-line or in-port " lastchance" protection in hydraulic and fluid systems and are not intended to replace typical filtration equipment. A new line of screen fittings offers nominal ratings from 65 to 480 m in standard sizes of –4 through –12 for use with Triple-Lok 37°flare and Seal-Lok O-ring face seal fittings.
are designed for in-line or in-port " lastchance" protection in hydraulic and fluid systems and are not intended to replace typical filtration equipment. A new line of screen fittings offers nominal ratings from 65 to 480 m in standard sizes of 4 through 12 for use with Triple-Lok 37°flare and Seal-Lok O-ring face seal fittings. Constructed with stainless-steel elements, the 4 size features a basket-style screen and the others are dome style. Applications include protecting gages and instruments, and shielding critical hydraulic components such as pump-compensator controls and proportional and relief valves. They also help prevent precision orifices from clogging. Bulletin 4300-SF details test results such as pressure drop, screen retention, and bidirectional flow capacity.
Parker Hannifin Corp., Tube Fittings Div., 3885 Gateway Blvd., Columbus, OH 43228, (614) 279-7070, parker.com/tfd
