Output is analog or PWM and maximum rotational speed is 300 rpm. A compressionmolded rotating neodymium disc magnet generates a relatively strong magnetic field for reliability and accuracy. And it makes sealed connections with industry-standard six-pin Packard Electric Metri- Pack connectors. It operates in temperatures from 40 to 185°F. Accuracy is to within 0.6% of full scale at room temperature and 0.9% of full scale over the entire temperature range. The sensor withstands 10-g vibrations at 20 to 2,000 Hz, and 50 g of shock, The sensor measures 25.8 41.1 50.7mm.
Aug. 21, 2025
