The one-piece coupling incorporates integrally machined selfcentering collars at both ends, eliminates conventional longitudinal slot, and provides close tolerance bore and keyway. The coupling is suited for line-shaft applications and instruments needing high-precision shaft alignment.
Stafford Manufacturing Corp., Box 277, North Reading, MA 01864, (800) 695-5551, staffordmfg.com
