Pushbutton Switch
Targeted for the electrical/electronic, medical, instrumentation, and control equipment industries...
Aug. 18, 2005
Targeted for the electrical/electronic, medical, instrumentation, and control equipment industries, the IP Series of pushbutton switches mount in a 13.6-mm hole and project less than 20 mm behind the front panel. The pushbuttons have maximum current/voltage ratings of 100 mA at 24 Vdc with an expected life of 200,000 cycles, and 2 A at 125 Vac with an expected life of 10,000 cycles. The switches are available in either solder lug or insulated wire-lead terminals and have gold-plated silver contacts. A two-position actuator indicates switch state by projecting higher when the switch is in the OFF position.-Features include shock and vibration resistance, round and square panel bezels, and sealing and illumination options. The black bezel frame comes with seven actuator color choices.
Apem Components Inc., 63 Neck Rd., Box 8288, Haverhill, MA 01835, (978) 372-1602, apem.com
