Programmable Automation Products
April 1, 2007
Sensor actuator interfaces Active SAIs are IP67-rated and provide wiring flexibility for modular and decentralized process control. Features & benefits
Features & benefits
  • Support Profibus, DeviceNet, CANopen, Ethernet, Ethernet/IP, Profinet, and Modbus/TCP
  • M8 and M12 socket connections; 24 Vdc with 8 × M12 inputs, 8 × M8 inputs, 8 × 0.5 A M12 outputs, 8 × 0.5 A M8 outputs, 8 × M8 configurable I/Os, and 8 × M12 configurable I/Os
  • Plug and play connections for sensors or actuators; LEDs at each port, bus, and supply connection
Weidmüller
Richmond, Va.
(804) 794-2877
www.weidmuller.com
Circle 166
Wireless transceiver
MRF24J40 2.4 GHz transceiver networks ZigBee protocol and wireless protocols in RF applications.
Features & benefits
  • Combines with 200 8-bit and 16-bit PIC microcontrollers and dsPIC DSCs
  • Provides source-code format to allow customization
  • Low-power consuming radio exceeds IEE 802.15.4 specifications
  • Features full media access controller and advanced encryption standard hardware encryption engine
Microchip Technology Inc.
Chandler, Ariz.
(888) 628-6247
www.microchip.com
Circle 167
