Speed reducers
AD reducers offer backlash as low as 3 arc-min and high shock load capacity in an interchangeable design.
Features & benefits
Input speeds to 6,000 rpm; output peak torque from 40 to 384 Nm (one-stage) and 38 to 4,000 Nm (two-stage)
Slotted interface allows quick and easy installation with any servomotor
Steel, aluminum, or stainless-steel housing
Contact of three planetary gears in steel crown gear with large diameter output provides high torsional stiffness
Two output bearings result in higher bearing capacity and long life
Onvio LLC
(603) 685-0404
www.onviollc.com
Circle 154
Worm gears
A double enveloping geometry features more teeth in contact with each other, to provide greater load carrying capacity in similar sizes, improved positional accuracy, longer life, and greater shock load capability.
Features & benefits
Series B has all aluminum housing in sizes from 1.33 to 3.54 in. centers
Model HP comes in sizes 1.500 to 28 in.
Accudrive series W and model RG offer high levels of precision for any type of servomotor
Cone Drive Textron
(888) 373-2663
www.conedrive.com
Circle 155
Anti-backlash gears
Series 1158 anti-backlash gears feature Fairloc integral hub fastening system to eliminate marred shafts and help phase adjustment, timing, position adjustment, and frequent removal problems.
Features & benefits
Gears are made of a set of two gear halves
Come in 303 stainless steel and 2024 aluminum; fit shafts ranging from to ¼ in. diameter
Suggested clearance between bore and shaft is 0.0001/0.0008 in.
Come in 120, 96, 80, 72, 64, and 48 diametral pitches and feature a 0.104-in. face width; sizes from 40 to 360 teeth with ODs from 0.642 to 3.083 in.
Sterling Instrument
(516) 328-3300
www.sdp-si.com
Circle 156
Corrosion-resistant gearbox
Stainless SG inline planetary gear and ternary intelligent linear actuator combination is comprised of 304 grade stainless steel shafts and housing and a guaranteed watertight motor/gearbox connection for washdown environments.
Features & benefits
No crevices for retaining fluids or promoting bacteria
Integrating all drive and control components into a single package, ternary provides easy installation with PLC control and low maintenance for washdown environments
Gearbox can be mounted to the ternary for rotary actuation
alpha gear drives Inc./Wittenstein motion control
(888) 534-1222
www.alphagear.com
Circle 157
Spiral bevel gears
Gears are carburized and hardened and come in matched sets.
Features & benefits
Ground tooth sets available; available as Q9 (lapped) and Q11 (ground tooth)
Sizes from 1 to 16 in.
Constructed of 8620 steel
Custom products available include spurs, helicals, and curvic couplings
Arrow Gear Co.
(630) 969-7640
www.arrowgear.com
Circle 158
Speed reducers
Cyclo Bevel Buddybox 3 speed reducers and gearmotors combine quiet, efficient Cyclo technology input with rugged spiral bevel gearbox output.
Features & benefits
⅛ to 40 hp; ratios from 11:1 to 26,000:1 and greater
Modular design is compact and offers flexible output speed and torque combinations
Taper Grip bushing system provides simple shaft mounting for self-alignment and backlash-free torque transmission
Sumitomo Drive Technologies
(757) 485-3355
www.sumitomodrive.com
Circle 159
Industrial gear units
X series industrial gear units offer high capacity and flexibility and come in 23 different sizes — each with a different torque rating — to deliver high torque graduation.
Features & benefits
Helical and helical-bevel gear technologies deliver torques to 4.1 million lb-in. with unit weights topping out at 4 ton
Symmetrical housing allows the gear units to be inverted to transform a left-handed unit into a right-handed one
Mount horizontally or vertically in foot, flange, or shaft-mounted designs
Internal gearing features ground finish for advanced fatigue strength properties and heightened resistance against breakage
SEW Eurodrive
(864) 439-8792
www.seweurodrive.com
Circle 160
Spur gears
Gears transmit rotary motion into uniform angular velocity and can be mounted on parallel, intersecting, or non-intersecting shafts.
Features & benefits
96 heat-treated gear teeth
20° pressure angle; 16.24 in. OD
Change the plane of rotation and increase or decrease speed of applied motion
Magnify or reduce applied force, and provide drive without slippage
Forest City Gear
(866) 623-2168
www.fcgear.com
Circle 161
