Products
April 1, 2007
Hybrid stepping motor NEMA size 11 stepper motor produces high torque in a small, RoHS-compliant package. Features & benefits 1.8 (200 steps/rev) bipolar
Features & benefits
  • 1.8° (200 steps/rev) bipolar and unipolar designs measure 28 mm2 × 32 mm long
  • Delivers accurate open loop control
  • Stack lengths of 32, 45, and 51 mm; maximum holding torques from 42 to 117 mN-m
  • Precision-honed stators and ground rotors form tight air gap
  • 4 or 6 leads; single or double-ended shafts
Nippon Pulse America Inc.
Radford, Va.
(540) 633-1677
www.nipponpulse.com
Circle 155
Pneumatic swing clamp
Swing clamp's arm rotates 90° clockwise or counterclockwise as it extends up and away from the work piece, providing clearance and access for loading and unloading.
Features & benefits
  • 8 bore sizes from 12 to 63 mm; strokes from 10 to 50 mm
  • Extruded aluminum bodies with 8 linear keyhole slots for external mounting or round profile sensors
  • Adjusting clamp bolt and four wrench flats on piston rod for easy clamp arm positioning
  • Ports can be NPT or BSP taper; counter-bored thru holes enable rigid mounting
  • Double acting operation, standard magnetic piston, and optional magnetic sensors enable positive cycles and work piece detection
Fabco-Air Inc.
Gainesville, Fla.
(352) 373-3578
www.fabco-air.com
Circle 156
Hand controls
TCH series electronic, industrial hand controls can be easily integrated into vehicle design.
Features & benefits
  • Non-contact sensor design
  • Control electric vehicles and electro-hydraulic systems
  • Replace conventional contact potentiometer hand controllers
Tuthill Controls Group
New Haven, Ind.
(260) 749-5105
www.tuthillcontrols.com
Circle 157
Motion controllers
SpiiPlus SA multi-axis, standalone motion controllers provide users with the power of PC-based control by using distributed multi-processor architecture running an on-board RTOS.
Features & benefits
  • Fixed 20 kHz servo update for every axis and deterministic control
  • Standard Ethernet and serial communications
  • Hardware position compare and capture; software development tools include Motion Simulator and FRF analyzer
  • Options include SIN-COS interpolator and input shaping
ACS Motion Control
Plymouth, Minn.
(800) 545-2980
www.acsmotioncontrol.com
Circle 158
Disconnect switches
Ferraz Shawmut's Sirco and Fuserbloc 600 Vac/250 Vdc fusible and non-fusible switches feature make-and-break power circuits under load and are UL, CSA, CE, and IEC-rated.
Features & benefits
  • Sirco available in 30 to 800 A ratings; those to 400 A come with visible blade contacts
  • Fuserbloc break up to 200 A and use double break contacts per pole, isolating fuse while switch is off
  • Available handles meet OSHA padlocking needs, NEMA configurations, defeater options, and NFPA 79
  • Work independently of speed and force of operator
  • Switches to 400 A use silver-tipped contact technology for high load breaks and long life; switches more than 400 A use self-cleaning technology for high short-circuit resistance
AutomationDirect
Cumming, Ga.
(800) 633-0405
www.automationdirect.com
Circle 159
All-in-one control
SilverPak 23CE features an integrated NEMA 23 high torque step motor, microstepping driver, intelligent controller, and optical encoder all in one compact unit.
Features & benefits
  • 3.41, 3.85, and 4.78 in. body lengths; up to 294 oz-in. holding torque
  • 3 A peak output current; operates from 12 to 40 Vdc; speeds to 16.7 MHz
  • Standalone operation; fully programmable ramps and speeds; software selectable hold and move currents; up to 256x microstepping resolution settings; and four user configurable digital I/Os
  • Intuitive commands can be preset to execute upon power up via Windows HyperTerminal, LabView, and Visual Basic
Lin Engineering
Santa Clara, Calif.
(408) 919-0200
www.linengineering.com
Circle 160
Guide rollers, cam followers
Power-Core miniature guide rollers and cam followers feature miniature ball bearings and self-lubricating, thermally installed precision machined plastic tires.
Features & benefits
  • O.D. as small as ½ in.
  • Handle shock and impact loading; resilient to flat development; run with low rolling resistance without lubrication
  • Eliminate rail wear and reduce metal-on-metal noise by up to 10 dB
  • Tire material does not wear steel or aluminum rails; does not generate metal particulates
Intech Corp.
Closter, N.J.
(201) 767-7797
www.intechpower.com
Circle 161
Linear bearings
X-Rail stainless-steel linear bearings are C-shaped to keep contaminants out.
Features & benefits
  • Sizes from 20 to 45 mm
  • Load capacities to 400 lb
  • Food-grade lubrication allows long life in washdown environments
Rollon Corp.
Sparta, N.J.
(877) 976-5566
www.rollon.com
Circle 162
Dual readhead encoders
DSi rotary encoders combine two error-correcting Signum SR readheads on an RESM ring and provide a customer-selectable propoZ reference (index) position that is unaffected by bearing wander or power cycling.
Features & benefits
  • Capable of installed accuracy of better than ± 1 arc/sec
  • Readheads located in 180° position; eliminate odd error harmonics, including eccentricity
  • Taper-locked to rotor shaft to eliminate coupling losses, oscillation, shaft torsion, and hysteresis errors
  • Operating speeds to 4,500 rpm; temperatures to 85° C
Renishaw Inc.
Hoffman Estates, Ill.
(847) 286-9953
www.renishaw.com
Circle 163
Motor testing equipment
Micro Dyne system tests micro, low-torque motors resolving from 0.0004 nN-m on a 2 mN-m scale.
Features & benefits
  • Maximum kinetic power rating of 4 W; maximum speed rating of 100,000 rpm
  • Hysteresis dynamometer and motor fixture (for motors from 5 to 30 mm)
  • Electronics unit has all-in-one dynamometer controller, wattmeter, power relay, and USB interface
  • M-Test 5.0 motor testing software, calibration software, connection cables, and calibration weights
Magtrol Inc.
Buffalo, N.Y.
(716) 668-5555
www.magtrol.com
Circle 164
Curved motion bearing
RVF Gonio curved slide way is a low-friction, non-recirculating curved motion bearing with precision cross rollers for minute curved motion.
Features & benefits
  • Hardened and ground raceways
  • Caged rollers provide stable movement, accept high loads, and install easily into workstations
  • Low frictional resistance and noise
  • Rotation range of ±5° to ±10°; 2 and 3-mm roller diameter
NB Corp. of America
Wood Dale, Ill.
(800) 521-2045
www.nbcorporation.com
Circle 165
