Machine vision software
NI Vision Builder software for Automated Inspection version 3.0 configures, benchmarks, and deploys complete machine vision applications without programming.
Features & benefits
State-machine process model allows graphic customization of application flow with conditional branches or iterative loops
Self-documentation allows for easy organization and sharing
New algorithms for golden template comparison, optical character verification, and data matrix grading
Acquires images from thousands of off-the-shelf cameras, including Camera Link, IEEE 1394, and GigE Vision
Processes images with 100+ vision tools, including geometric matching, OCR, and particle analysis
National Instruments
Austin, Texas
(800) 258-7022
www.ni.com/vision/vbai
Circle 169
Vision camera
VC4458 Smart Camera is suitable for high-speed applications, with a maximum frame rate of 250 fps and an integrated 1 GHz DSP from Texas Instruments.
Features & benefits
High-speed encoder interface
RS232 and Ethernet interface and external trigger input for jitter-free image recording at high frequencies
1/3 CCD sensor provides 640 × 480 pixel resolution
SVGA video output, four digital PLC inputs, and four digital outputs
4 MB Flash Eprom and 64 MB SDRAM standard
Vision Components GmbH
Hudson, N.H.
(603) 598-2588
www.vision-components.com
Circle 170
Mechanical torque limiters
Torque limiters isolate driving from driven elements quickly once torque reaches a preset overload value.
Features & benefits
1,400 to 20,000 N radial load capacity
Disengagement speeds of 1,200 to 4,000 rpm (single and multi-position) and 3,000 to 14,700 rpm (full disengagement)
Precise overload protection; backlash-free and torsionally rigid
Low residual friction following disengagement and low moment of inertia
Nexen Group Inc.
Vadnais Heights, Minn.
(800) 843-7445
www.nexengroup.com
Circle 171
Drive controller
Square D brand M-Flex enclosed drive controller offers adjustable speed for motor control applications.
Features & benefits
Telemecanique brand Altivar 61 or 71 ac drive for high functionality
Altivar 61 offers constant torque/heavy-duty ratings (150% current limit) of 1 to 4 hp at 208 to 230 V and 1 to 450 hp at 460 V
Altivar 71 offers variable torque/light-duty ratings (110% current limit) of 1 to 50 hp at 208 to 230 V and 1 to 500 hp at 460 V
Type 1 general purpose or type 12/12K drip and dust-proof enclosures in integrated or barriered designs
Ac line reactor provides transient protection from surge and overvoltage; minimizes line harmonics
Schneider Electric
Palatine, Ill.
(847) 397-2600
www.us.squared.com
Circle 172
Linear guideways
Linear guideway assemblies offer high-speed, high-accuracy, long-lasting, and trouble-free performance with the use of a recirculation system for smooth motion with little noise.
Features & benefits
Lube-retaining end caps and sealed bearing blocks reduce friction
End seals, with optional double seals and scrapers, protect against contamination
Several series available — ATH (for heavy loads), ATE (with interchangeable block), ATM (miniature model), and ATH E2 (self-lubricating)
28-page brochure detailing all product lines now available
Warner Linear, Div. of Altra Industrial Motion
Belvidere, Ill.
(800) 234-3369
www.warnerelectric.com
Circle 173
Hollow-shaft encoder
HS35M magnetic, hollow-shaft encoder features shaft seals and bearings that stay sealed to keep out contamination.
Features & benefits
Fits shafts from 0.5 to 1.125 in. for end-of-shaft and through-shaft applications
Resin housing resists acids, bases, oils, and chemicals; eliminates shaft current or grounding problems
Two large bearings protect against damage
Mechanical barriers prevent flexing or failure
Avtron Manufacturing Inc.
Independence, Ohio
(216) 642-1230
www.avtronencoders.com
Circle 174
Metric retaining rings
Single-turn, spiral retaining rings are available for internal and external grooves.
Features & benefits
More than 400 rings available in carbon and stainless steel
Diameters from 6 to 300 mm; custom sizes from 5 to 2,300 mm
Three series match European DIN 471 and 472 grooves and aerospace specification MA 4017 and 4016
Smalley Steel Ring Co.
Lake Zurich, Ill.
(847) 719-5900
www.smalley.com
Circle 175
Brushless servomotors
MUS brushless servomotors are fitted with high-flux density Neodymium iron boron magnets to reduce motor inertia.
Features & benefits
Torques from 380 W to 3.5 kW
High peak torques for acceleration and deceleration
Thermal sensor location eliminates overheating and demagnetizing
AC Technology Corp., a member of the Lenze Group
Uxbridge, Mass.
(508) 278-9100
www.actech.com
Circle 176
Pick-and-place unit
AGE-S unit guarantees compensation beyond positioning accuracy of the robot for medium and heavy load pick-and-pick applications.
Features & benefits
X, Y, and X compensation directions minimize size and weight
Resists bending moments; complies to workpiece positions to minimize assembly and unloading forces
Compensation ranges of ±12 mm (X and Y) and 14 mm (Z); may be fixed by pneumatic device for XY and Z direction
Payloads from 5.5 to 100 kg
Schunk Inc.
Morrisville, N.C.
(919) 572-2705
www.schunk.com
Circle 177
Position sensors
TEX position sensors are rated to IP66 and feature differential pressure compensation technology to equalize pressure that builds up from rod movement on linear sensors.
Features & benefits
Stroke lengths to 300 mm; operating life to 20 million movements
Compact, 18-mm housing
Linearity of ±0.05% with resolution better than 0.01 mm
Pivot heads provide large angle of free movement to eliminate side-load errors
Mounting options include fixing clamps for center bushing or bolt-through flange plates
Novotechnik U.S. Inc.
Southborough, Mass.
(508) 485-2244
www.novotechnik.com
Circle 178
Motion, logic controllers
SMLC-SA single axis controllers combine high-performance drive technology with IEC 61131-3 programming capabilities.
Features & benefits
Replace standalone PLC and controller/drive; reduce wiring complexity, panel space, and programming
600 to 24,000 W power; 115 to 480 Vac input voltage
Scalability from one to 16 axes
Built-in I/O: 27 digital and four analog; expand to thousands of I/O points with Wago 750 series Ethernet I/O
Ormec
Rochester, N.Y.
(800) 656-7632
www.ormec.com
Circle 179
