Drives line
A new line includes SCR, PWM, SCR regenerative, and ac variable frequency versions.
Features & benefits
Pairs with gearmotors, available to 3 hp, in both U.S. and EU frequencies
Suitable for food preparation equipment, ventilation systems, medical pumping, and positioning equipment
Bison Gear and Engineering Corp.
St. Charles, Ill.
(630) 377-4327
www.bisongear.com
Circle 178
RoHS motors
Line of fractional-hp motors is now lead-free.
Features & benefits
Solder is 96.4% Sn, 3% Ag, 0.5% Cu
Flux and cleaner processes remain the same
Groschopp Inc.
Sioux Center, Iowa
(712) 722-4135
www.groschopp.com
Circle 179
Brushless motors
Mdrive 42AC Plus high-torque, brushless motors include a fully integrated drive and control electronics for high performance and smoothness.
Features & benefits
20 µm step resolutions up to 51,200 step/rev (degrees, metric, arc min)
Single supply of 120 or 240 Vac
Holding torque of 1,147 oz/in. (single length) or 2,294 oz/in. (double length)
No dithering at zero speed, low-speed stability, and built-in regeneration circuitry
High-positioning accuracy and starting torque
Available in step and direction (microstepping) and fully programmable versions
Intelligent Motion Systems Inc.
Marlborough, Conn.
(860) 295-6102
www.novantaims.com
Circle 180
Non-contact sensors
RSC 1300 non-contact rotary sensors use vertical Hall technology and a cross structure that affixes to a silicon chip to provide 360° measurements with 10-bit resolution.
Features & benefits
Measure 13 × 20 mm
Support rotating speed up to 10,000 rpm with sample rate of 10,000 kHz
Independent linearity of ±0.3% and repeatability to 0.1% of signal range
Stainless-steel housing; sealed to IP65
Novotechnik U.S. Inc.
Southborough, Mass.
(508) 485-2244
www.novotechnik.com
Circle 181
Ruling slides
Precision glass slides let users evaluate resolution, field distortion, and parfocal stability of fluorescent vision systems.
Features & benefits
Fluorescent backing lets users test system performance using application's UV light source
Incorporates Ronchi rulings deposited on fused silica
Resolutions available from five to 600 line pairs/mm
Edmund Optics Inc.
Barrington, N.J.
(800) 363-1992
www.edmundoptics.com
Circle 182
Gear drives
Hub3 stainless steel helical and Poweratio 4000 inline gears are newest additions to drive line.
Features & benefits
Hub3 rated to 18 hp, Poweratio 4000 to 125 hp
Hub3 is available in two models and features smooth machined exterior for easy cleaning and no contaminant buildup
Poweratio 4000 is mechanically and dimensionally interchangeable with most models and comes in eight designs
Hub City Inc. Regal-Beloit Corp.
Aberdeen, S. Dak.
(605) 225-0360
www.hubcityinc.com
Circle 183
Vision sensors
LightPix AE20 is an integrated lighting, CCD color camera and CPU vision sensor programmed with AETool software.
Features & benefits
Interchangeable inspection packages — color judgement, area, and pattern matching, measurement, and edge and peak detection
Connect to PLC and HMI
Aluminum IP67 construction withstands harsh environments
Panasonic Electric Works Corp. of America
New Providence, N.J.
(877) 624-7872
www.pewa.panasonic.com
Circle 184
