Product Spotlight: Right-Angle Photoelectric Sensors
Feb. 21, 2008
The M18 photoelectric sensor, with a right-angle prism, is designed to flush mount onto a conveyor to look across the belt or rollers.
The sensors produce high-intensity, pulsed, visible red (660-nm) light for high immunity from interference from other bright lights. A fourth-wire output alerts the control system if there is dirt buildup during operation so any deposits can be removed before object detection becomes critical. Housed in a M18 metal housing, the sensors feature high shock resistance, 10 to 30-Vdc voltage range, overload protection, and are short-circuit and inverse-polarity proof. The units are also stable from –25 to 55°C and can switch output current of 200 mA.
Contrinex Inc.,
2 Business Park Rd., Old Saybrook, CT 06475,
(866) 289-2899,
contrinex.com
Strategizing for sustainable success in material handling and packaging
Download our visual factory brochure to explore how, together, we can fully optimize your industrial operations for ongoing success in material handling and packaging. As your...
