Product Spotlight: Proximity Sensors
March 1, 2007
Inductive sensors Pre-programmed ASIC technology on Mega proximity sensors reduces size and improves sensing consistency. Features & benefits 3, 4, 6.5-mm
Inductive sensors
Features & benefits
  • 3, 4, 6.5-mm and M5, M8, M12, and M30 diameter housing sizes
  • Detect metal objects at distances from 0.8 to 15 mm; sensing distance programmed after sensor built
  • Small circuit board reduces length
  • Operate in temperatures from -25° to 75° C; IP67-rated stainless-steel or nickel-plated brass housings
  • Shielded, quasi-shielded, or unshielded mountings; short-circuit and reverse polarity protection included
Baumer Electric
Southington, Conn.
(800) 937-9336
www.baumerelectric.com
Circle 151
High-temperature sensors
CQ40 and CQ80 inductive proximity sensors have a sensing head separate from the electronic amplifier assembly for long sensing ranges.
Features & benefits
  • Operating temperatures to 250°C
  • Interconnected with standard M12 eurofast quick-disconnects using Teflon cables encased by aluminum sleeve
  • Separate components reduce maintenance and operating costs: Only the sensing head exposed to high temperatures needs replacement
Turck
Minnetonka, Minn.
(800) 544-7769
www.turck.com
Circle 152
Speed monitors
Programmable M18 speed monitors are DIN-rail mountable and evaluate pulse frequency, rotational speed, linear speed, and machine cycles.
Features & benefits
  • 4-wire, dc monitor provides 12-mm non-flush sensing range
  • Three LED status display for power, switching, and input pulses
  • Designed for rotational speeds to 18,000 pulse/min
  • Pulse output for monitoring rev/min; switching output indicates under-speed and over-speed conditions
  • 100 to 240 ac/dc or 24 Vdc operating voltage
ifm efector inc.
Exton, Pa.
(800) 441-8246
www.ifmefector.comCircle 153
Capacitive switches
Proximity switches monitor levels of liquids, pastes, and bulk materials, even through non-metallic dividing walls.
Features & benefits
  • 4-wire in sizes M12, M18, and M30 (PNP or NPN, with changeover outputs; 2-wire (ac/dc, NO) in sizes M18 and M30, or embeddable or non-embeddable versions
  • Connection made by standard 2-m cable or S12 connector
  • Suitable as limit and contact-free position switches, monitoring and positioning, pulse generators for counting, distance and speed measurement
  • PPO or PTFE synthetic housing and 304 stainless-steel or nickel-plated brass housings; potted in epoxy resin
Contrinex Inc.
Old Saybrook, Conn.
(866) 289-2899
www.contrinex.com
Circle 154
