Capacitive sensors
Elite series non-contact sensors measure very small displacements of conductive materials with high resolution in precise positioning applications.
Features & benefits
0.01 to 10 mm measuring ranges; 1 nm resolution
CPL190 and CPL290 capacitive sensors and MM190 meter/signal processing module
Differential analog signals to data acquisition system for high signal to noise ratio
Odd and even-numbered channels use inverted excitation signals to null ground current flow and eliminate noise and offset in differential measurements
Lion Precision
St. Paul, Minn.
(651) 484-6544
www.lionprecision.com
Circle 151
Encoder position sensors
R-series sensors offer fast data processing and accurate sensing for servo control applications.
Features & benefits
Use Temposonics magnetostrictive technology and provide same absolute serial encoder interface as in CNCs and motion controls
Position sensing as low as 1 mm; resolution of 1 to 100 µm
SSI output has optional data update rate of 250 µsec synchronized with external clock, regardless of stroke, with as few as 16 µsec between measurement data clock cycles
Measurement non-linearity correction improves sensing accuracy to as low ±10 µm
MTS Systems Corp., Sensors Div.
Cary, N.C.
(919) 677-0100
www.mtssensors.comCircle 152
Displacement transducers
Compact WA and WI inductive displacement transducers are made for measurements with close to infinite resolution, 80 mV/V sensitivity, and IP67 protection.
Features & benefits
WA has maximum measuring length of 500 mm; accuracy of 0.2%
WA features quarter-bridge design with optional 0.5 to 10 V output
WI inductive half-bridge models come with measuring lengths of 2.5, 5, and 10 mm; shaft diameter of 8 mm
WI have linearity deviation of ±0.2%
HBM Inc.
Marlborough, Mass.
(800) 578-4260
www.hbm.com
Circle 153
Magnetostrictive position sensors
Posichron PCST27 sensors are absolute, contact, and wear-free sensors rated to IP69K for underwater use in hydraulic cylinders.
Features & benefits
Operating pressure to 5,800 psi; 19 ft measuring range
Analog output of 0-10 V, 4-20 mA, digital pulse output start/stop, or SSI
3/4 in.-16 thread or M18 × 1.5 threads available
Tolerate 100 shocks of 50 g; each has 11 msec duration
Full-scale linearity rating of ±0.02%
ASM Sensors Inc.Elmhurst, Ill.
(630) 832-3202
www.asmsensors.comCircle 154
