Product Spotlight: Dispensers and Metering Pumps
Sept. 11, 2008
The Fluid Metering Catalog covers operating principles, pump capacities, motor characteristics, materials of construction, and ordering information.
New products include the IVSP Industrial Variable Speed Pump with controller, VMP Series of programmable variable-displacement dispensing and metering systems, and FMI pumps.
The IVSP has a rugged …-hp three-phase high-torque motor for viscous fluids and a space-saving DIN-mount controller for process-control panels.
The VMP system can program and store up to 100 combinations of dispense-control parameters, including piston displacement, flow rate, rpm, forward, reverse, quick-prime, and suck back. A TSITSI Touch Screen Interface adds intuitive programming of up to 16 pumps simultaneously.
With the CeramPump valveless piston design, FMI pumps have only one moving part and a ceramic and fluorocarbon fluid path. The pumps are capable of dispensing from 2 μliter/dispense to 4,600-ml/min continuous metering with pressures to 100 psig at an accuracy of 1% or better.
Fluid Metering Inc., 5 Aerial Way, Suite 500, Syosset, NY 11791, (800) 223-3388, fmipump.com
Sept. 16, 2025
Sept. 16, 2025
Sept. 16, 2025
