Product Spotlight: Ball/Leadscrews
June 1, 2007
Leadscrew assemblies Line of leadscrew assemblies includes acme leadscrews, advanced coatings, and anti-backlash nuts to minimize lost motion while maximizing
Line of leadscrew assemblies includes acme leadscrews, advanced coatings, and anti-backlash nuts to minimize lost motion while maximizing system stiffness.
Features & benefits
  • Diameters range from ⅛ to ⅝ in. with leads as fine as 0.012 in. and fast leads to 1.25 in.
  • Rolled from precision ground 303 stainless steel
  • Come with Black Ice coating, a PTFE process that eliminates flaking
  • Technical catalog highlights leadscrew assemblies and anti-backlash nuts
Haydon Switch & Instrument Inc.
(203) 756-7441
www.hsi-inc.com
Circle 151
Roller pinion system
Precision roller pinion system is an alternative to precision ballscrews, converting rotary motion into precise, backlash-free linear motion.
Features & benefits
  • Bearing-supported rollers mesh with optimized tooth profiles, achieving smooth, trouble-free motion
  • Accurate positioning speeds to 660 m/min
  • Low friction design minimizes heat and wear
  • Segments of rack allow the system to be configured for any length
Nexen Group Inc.
(651) 286-1054
www.nexengroup.com
Circle 152
Rolled ballscrews
Grade C10 metric rolled ballscrews come in low-dust raise greased versions in threaded outer diameter 10, lead 4 sizes.
Features & benefits
  • Induction-hardened for rigidity and long performance
  • 100 to 318 mm lengths available; configurable in 1-mm increments
  • Carburized nut or induction hardened thread shaft with phosphate coating available
  • Shaft supports, actuator drives, and linear motion units available
  • Greasing keeps dust raised to a minimum
Misumi USA
(800) 681-7475
www.misumiusa.com
Circle 153
Self-locking leadscrews
Non-ball leadscrews for vertical applications self-lock and prevent backdriving, without an external brake.
Features & benefits
  • Diameters from ⅛ to 15/16 in. with leads from 0.02 to 3 in.
  • Sliding friction between nut and screw converts rotary input motion into linear output motion
  • 303 stainless steel; easily machined without being hardened
  • Accuracy comparable to ground ballscrews
Kerk Motion Products Inc.
(603) 465-7227
www.kerkmotion.com
Circle 154
Miniature ballscrews
KSS miniature ballscrews come in 224 different ground configurations with finish end machining.
Features & benefits
  • SG series has diameters from 4 to 14 mm and leads from 1 to 15 mm
  • SG comes with C3 and C5 precision classifications and travels to 490 mm
  • SR rolled screw series comes in diameters from 5 to 14 mm and leads from 1 to 20 mm
  • SR comes with C7 and C10 grades and travels to 400 mm
  • SD bi-directional series comes in right and left-hand threads
The Precision Alliance
(803) 396-5544
www.tpa-us.com
Circle 155
