Pneumatic Transducers For Explosive Atmospheres
Aug. 4, 2005
The Type-550X miniature electropneumatic I/P, E/P transducer complies with ATEX directives 94/9/EC for equipment in potentially explosive atmospheres.
Type-550X electronic pressure regulator converts a variable current or voltage signal to a proportional pneumatic output. Features of the compact unit include a NEMA-4X housing; input and output ports on both front and back; high flow capacity delivers quick actuation of dampers, louvers, valves, and cylinders; and removable external orifice. A built-in volume boost provides up to 20-scfm airflow capacity for increased speed control. Unit specifications include: input signal of 4 to 20 mA; output pressure for the standard range includes 3 to 15 psig, 3 to 27 psig, 6 to 30 psig, 2 to 60 psig, and 3 to 120 psig; output pressure for the zero-based range includes 0 to 30 psig, 0 to 60 psig, and 0 to 120 psig; and supply pressures up to 100 psig (standard range) and 130 psig (zero-based range).
ControlAir Inc.
8 Columbia Dr.
Amherst, NJ 03031
(603) 886-9400
controlair.com
Strategizing for sustainable success in material handling and packaging
Download our visual factory brochure to explore how, together, we can fully optimize your industrial operations for ongoing success in material handling and packaging. As your...
Fueling the Future of Commercial EV Charging Infrastructure
Miguel Gudino, an Associate Application Engineer at RS, addresses various EV charging challenges and opportunities, ranging from charging station design strategies to the advanced...
