Pneumatic SOLUTIONS
May 1, 2005
Proportional valve CD An introductory CD highlights the features and specifications of EVP proportional-control valves. FEATURES & BENEFITS Control air
FEATURES & BENEFITS
  • Control air and gas flow, varying flow by changing solenoid current
  • Consistent gain provides high accuracy
  • Controlled with dc current and pulse-width modulation, open or closed loop, in a broad range of applications
CLIPPARD INSTRUMENT LABORATORY INC.
Cincinnati, Ohio
(888) 439-6264
www.clippard.com/evp-h
Circle 239
Modular pneumatic actuators
Line of short stroke pneumatic actuators is offered in modular configurations where multiple units are integrated into a single housing.
FEATURES & BENEFITS
  • 25 to 175 lb thrust force with standard plant air input
  • 0.1 to 2 in. stroke lengths
  • Operates on standard four-way valve circuits for individual or simultaneous motions
  • Provides several independent axial forces
MACK CORP.
Flagstaff, Ariz.
(928) 526-1120
www.mackcorp.com
Circle 240
Pneumatic hoses
Chainflex Air pneumatic hoses are designed for use in an Energy Chain System and are resistant to abrasion, oil, and coolant.
FEATURES & BENEFITS
  • Tested for more than 10 million cycles at a bend radius 10 times the outer diameter
  • Durable polyurethane construction
  • More than 10 sizes available
IGUS INC.
East Providence, R.I.
(401) 438-2200
www.igus.com
Circle 241
Air cylinders
NR series stainless steel air cylinders are designed to maximize performance, and come with stainless steel piston rods, roll-formed threads at both ends of the piston, and pre-lubrication.
FEATURES & BENEFITS
  • 5/16 to 3 in. bore sizes
  • Up to 32 in. stroke length
  • 250 psig
  • Adjustable cushions and single and double rod
  • Standard temperatures of -10° to 165°F
AIRCYLINDERSDIRECT.COM
(866) 404-5300
www.aircylindersdirect.com
Circle 242
