Pneumatic Solutions
June 1, 2006
Rodless band cylinders BC series of rodless band cylinders use Endurance Technology to extend life in demanding applications. Features & benefits Four
Features & benefits
  • Four lines — BC4, BC2, BC3, and BC3D — deliver peak performance and durability
  • Stainless-steel band, rigid extruded aluminum tube, and internal air cushioning
  • Load supported through entire stroke to minimize seal wear
Tol-o-matic Inc.
Hamel, Minn.
(800) 328-2174
www.tolomatic.com
Circle 186
Cushioned air cylinders
ISO/VDMA cylinders' adjustable cushions feature reduced cycle times, noise, and vibration, and increased cylinder life.
Features & benefits
  • Cushioning eliminates end-of-stroke bounce
  • Bore sizes from 32 to 125 mm, with tie rod version to 320 mm
  • Rated for pressures to 150 psi in temperatures from 5° to 158° F
  • Stainless-steel piston rod standard
Bosch Rexroth Corp.
Lexington, Ky.
(859) 254-8031
www.boschrexroth-us.com
Circle 185
