Rodless band cylinder
Ultran Band rodless cylinder seals mechanical piston/yoke connections.
Features & benefits
  • 18 to 63 mm bore sizes (inch available)
  • Stroke length to 3 m
  • Sealing efficiency rating of 100 sccm leakage
  • Cushioning and position-sensing capabilities; optional side-guiding attachment increases load capacity
Bimba Manufacturing
Monee, Ill.
(708) 534-8544
Circle 134
Air cylinders
Pancake II interchangeable pneumatic cylinders offer high load bearing capacity, reduced friction, and zero slip stick.
Features & benefits
  • Four styles and eight bore sizes from ½ to 4 in.
  • High strength, self-lubricating composite cylinder barrels and oversized, non-metallic piston rod bearings
  • Standard, non-rotating, force-multiplying, and 3-position models
Fabco-Air Inc.
Gainesville, Fla.
(352) 373-3578
Circle 135
