Pneumatic SOLUTIONS
Aug. 1, 2005
Valve manifolds The XV module connection allows integration of pneumatic valves by most well-known manufacturers directly into the system. FEATURES &
Valve manifolds
FEATURES & BENEFITS
  • 24 digital outputs for up to 24 valves, in a compact DSUB housing
  • Direct cConnection via 25-pin connector for high openness
  • Use with CANopen, DeviceNet, ProfiBus, Ethernet Powerlink
B&R INDUSTRIAL AUTOMATION CORP.
Roswell, Ga.
(770) 772-0400
www.br-automation.com
Circle 108
Magnetic cylinder sensors
C-slot pneumatic cylinders feature Giant Magnetoresistive technology and offer high repeatability, fast response times, and immunity from long-term effects of magnetic fields.
FEATURES & BENEFITS
  • Unlimited cycles reduce sensor replacement through cylinder's life
  • 15 mm in length
  • 3-wire, normally-open, PNP or NPN outputs
  • Top-load mounting eliminates need to remove endcaps
IFM EFECTOR INC.
Exton, Pa.
(800) 441-8246
www.ifmefector.com
Circle 109
Repairable cylinders
EN series NFPA interchangeable cylinders use extra long graphite-filled cast iron rod bushings to increase stability.
FEATURES & BENEFITS
  • Bores sizes of 1½ to 6 in., rod diameters of ⅝ to 1¾ in.
  • Strokes to 48 in., pressure of 250 psig
  • Single and double rod, 17 mounting styles
  • Temperatures from -10° to 165° F
AIRCYLINDERSDIRECT.COM
Nashville, Tenn.
(866) 404-5300
www.aircylindersdirect.com
Circle 112
Pneumatic hoses
Chainflex Air pneumatic hoses used in an Energy Chain System offer flexibility and resistance to abrasion, oil, and coolant.
FEATURES & BENEFITS
  • Tested for more than 10 million cycles at bend radius 10 times outer diameter
  • Durable polyurethane offers long-lasting performance
  • More than 600 sizes and styles (power and control cables, air hoses, data cables, servo cables, and fiber optic cables)
IGUS INC.
East Providence, R.I.
(800) 521-2747
www.igus.com
Circle 111
Rodless cylinders
Series MY2 and MY3 rodless cylinders use low-profile designs for space-saving of 30% or more compared to conventional designs, and exceed 3,000 km life.
FEATURES & BENEFITS
  • Stroke-adjusting, double-acting MY2 requires no lubrication for high-precision linear transfer applications
  • Thrust force of 40 to 1,005 N, strokes of 100 to 5,000 mm, maximum operating speed of 1,500 mm/sec (MY2)
  • Unguided MY3 features compact height and length for basic linear motion; long stroke to 3,000 mm
  • MY3 offers bore sizes of 16, 25, 40, and 63 mm; features same functionality of MY1B
SMC CORP. OF AMERICA
Indianapolis, Ind.
(317) 899-4650
www.smcusa.com
Circle 110
March 13, 2024
March 13, 2024
March 13, 2024
March 13, 2024
