The manifolds come with or without digital inputs and auxiliary power. Valve station are four-way, two-position, or dual three-way, two-position, or a blanking plate. Valve flows are 0.2 Cv (200 1/min) with pressure of 29 to 116 psi. Voltage is 24 Vdc with a protection rating of IP67 (NEMA 6). The valves come with push-in fittings for 4-or-6-mm plastic tubing or M7 threaded ports.
Bosch Rexroth Corp., 5150 Prairie Stone Pkwy, Hoffman Estates, IL 60192, (800) 739-7684, www.boschrexroth-us.com
