Pelican™ Introduces The 1430 Top Loader Case
Pelican Products, Torrance, CA, is a leading manufacturer of high-impact, watertight equipment Protector™ cases and safety approved, technically advanced flashlights, has released the 1430 Top Loader Case.
Nov. 3, 2005
2 min read
Pelican Products, Torrance, CA, is a leading manufacturer of high-impact, watertight equipment Protector cases and safety approved, technically advanced flashlights. Pelican has unveiled the 1430 Top Loader Case.
The 1430 Top Loader features Pelican's Protector Case plus nearly 1,100 cubic inches of usable storage space and will feature a unique top loading design with a rubber over-molded handle for easy transport. The case will also be available with optional features such as a shoulder strap, lid organizer, "mobile office" file holder kit and padded dividers for photography and computer equipment. Optional accessories such as Pick 'N' Pluck foam, canoe attachment brackets and TSA-Accepted PeliLocks are also available.
The 1430 Top Loader's engineering-grade polymer, cell-core construction helps it protect sensitive equipment under extreme conditions. Additional standard features include a lid equipped with a polymer o-ring for a dust and waterproof seal, dual action latches that have been tested to a failure threshold of nearly 400 pounds (but open with a light pull), and a pressure-balancing, moisture fighting, automatic Gore-Tex purge valve. Pelican Cases have a trademarked "Dual Band" design.
The 1430 Top Loader is backed by a Lifetime Guarantee: According to Pelican Products, if "You break it, we replace itforever."
For more information, contact the company:
23215 Early Ave.
Torrance, CA 90505
Phone: (310) 326-4700 or (800) 473-5422 (Outside CA)
Fax: (310) 326-3311
www.pelican.com
[email protected]
