PCI Express
May 11, 2006
Press-fit, vertical PCI Express cardedge connectors let manufacturers avoid soldering by connecting highspeed, serial PCI Express architectures to the thicker system boards found in server applications.
Press-fit, vertical cardedge connectors let manufacturers avoid soldering by connecting highspeed, serial architectures to the thicker system boards found in server applications. The connectors target 0.093 to 0.165-in.-thick PCBs. Each serial connection supports 2.5 Gbytes/sec data rate in both directions.
FCI, 825 Old Trail Rd., Etters, PA 17319, (800) 237-2374, www.fciconnect.com/pciexpress
